The rule of thumb for wiring using aluminum or CCA is you need to go one size larger than with copper. This will eliminate any concerns about voltage loss, or current carrying rating. So if you need a #8 you should use #6. For a battery cable from trunk to starter I'd use 2/0 CCA.
