Im building ladderbars for my Fiat gasser, and i`m at the point to get the materials for it.
Lower tube will be 1" (2.5cm) and the upper a little bit under 7/8" (around 2cm).
I need some heim joints for the end that connects to the chassis. Figured i can order them from USA since they are very expensive over here... (as everything else), but what sizes am i looking for?
I think the best way is thread the lower tube..so.. help me out please :)
I use 5/8" or 3/4" for that size tube, but I also use weld bungs, instead of threading the tube. If you plan to thread the tube you'll probably have to go to 1" heims, and the prices for heims and bolts will be extravagant! I can't even guess what they'll cost, as my supplier doesn't carry anything larger than 3/4".
Here's where I get them cheapest:
http://www.qscomponents.com/
If you are building "real" ladder bars, not just for looks, I'd go with the 3/4 heims. That's what most all of the factory built ones use. Remember, when you launch, the forces that are planting the tires are also trying to bend the shank of that front heim.
