I wanted to keep the same length/layout as stock shocks that came on the car for simplicity in sourcing replacements down the road. Lower mounts are home made, sandwiched between the axle and spring. (Used an extended center pin to keep anything from shifting). The top mounts are home made as well, attached to the frame where the old bump stops/shock towers were
If I did it again, I might make a few holes in those triangular plates up top they are a bit overkill and they might look better with holes. Still might drill 'em.
