1 - 5 of 5 Posts
What is everyone running for a thermostat and radiator cap? I have been doing a lot of reading and I am going to run a 180 degree thermostat and a 16 lb radiator cap. for what I am doing that should be enough.
it's what i've ran in every build for years . i use a 16 in syclone fan and aluminum radiator . i'm in texas and cars run 200 in summer. you need a little heat to burn this crappy gas today .
That's the same combo I also run. As long as the radiator is a modern or newly manufactured radiator that can handle a 16 lb. cap's pressure.
it is a modern 3 row aluminum radiator with 2 electric fans. so I am guessing I should be good.
1 - 5 of 5 Posts
