Thanks for the new area! Now let's see some ideas guys to make our gasser builds easier!
I'll start with one I used when building my Austin. I made up wiring harnesses to go from the fuse block to the front, and rear. Counted and numbered all the wires, then addeed a couple extras in case of futre additions. For the run to the rear I bought some large black corrugated flex tubing and pulled it inside the frame after putting all the wires inside. Later when I needed a couple extra wires to the back I simply tied them onto the spare wire (along with another extra) and pulled them easily through the tubing with some wire lube. Now I had my extra wires, plus a spare to use as a pull wire again if needed.
Didn't use the tubing up front as the run is short, and easy to access.
