1 - 1 of 1 Posts
SWAG V3.0 Portaband Table
Here at SWAG our Portaband tables are built for individuals looking for quality, 100% American made tools at an affordable price. Designed for those working with limited space and or those looking to maximize the full potential of their hand held band saws.
As with all things that are an industry first, product upgrades and user feed back have slowly morphed our first vice mounted Portaband table, the SWAG V1.0. Soon a bolt on miter gauge slide attachment was offered for the V1.0. Within a couple months over 40% of the orders placed had the bolt on miter gauge slides included. Product evolution and expansion has led us to SWAG Portaband table V3.0 which features built in dual miter gauge slides, bolt on 1/8" thick steel legs to greatly reduce shipping cost, a removable steel center section and an improved blade slot with narrower window to reduce potential blade binding. The SWAG V3.0 is still compatible with all Milwaukee and Dewalt deep throat Portaband tables listed below.
To convert your saw into a vertical band saw installation could not be any easier, remove the factory foot guards two or three screws depending upon model and reinstall the removable center section with the provided fasteners. With the SWAG V3.0 there is a thumb knob included in the kit. Insert the saw into the stand and install the thumb knob into the threaded hole in the removable center section. You now have a saw that performs two functions, a portable band saw and a vertical band saw that does not require any tools to switch between the two functions
Our V3.0 table is cut on a CNC laser out of 3/16" thick steel plate, formed on a CNC press brake and weighs in at ~ 20 pounds for ultimate durability. The Table dimensions are 9.75 tall, 11" deep & 13.5" wide. With the saw installed the overall dimensions are ~22" tall, 18" deep & 13.5" wide.
This kit contains all the necessary hardware to attach your Dewalt or Milwaukee deep throat Portaband to the SWAG Portaband tables.
Fits the following models.
Dewalt deep throat model #'s DWM120, DWM120K, D28770, D28770K
Milwaukee deep throat model #'s 6230, 6230N, 6232, 6232-6N, 6236, 6238, 6238N, 0729-20, 0729-21
Milwaukee compact model #'s 6242-6, 2629-22 M18, 2626-20 M18
Note: The Cordless V28 Milwaukee saws will require a 1/2" spacer under the table legs to allow clearance for the battery pack.
If you own the new Milwaukee 6232-20, 6232-21, 6238-20 & 6238-21 saws please click HERE for our V4.0 Portaband tables.
Note: Our tables can easily be modified on your end to fit Portercable, Bosh and Makita Portabands, however our tables will not fit the Harbor Freight Portaband saws.
Optional Accessories
120V 15 Amp Power Maintained Foot Switch
Imagine how easy your job is going to be using the foot pedal to start and stop your SWAG Portaband table. Plug your Portaband power chord into the 15 amp outlet on the foot pedal. Plug the foot pedal chord into a 110 volt outlet. Press the pedal to start the saw, then press again to turn off.
1 - 1 of 1 Posts
