I'll roll the dice here and start this off. Let's see pix of solid axle steering set ups, and discuss the do's and don'ts of setting one up. I'd like this to be a technical thread of sorts, so that someone who is considering installing or having issues with thier currant set up, can get some REAL information, ask REAL questions, and get REAL answers.
Here's the run down of what I have done on mine so far. In my 55 Chev I installed a 59 Chev truck axle, hung with 6" lift springs for a CJ5. Frame is stock (uncut) and retains the stock steering box. I took the lefthand steering arm from the 55/57 car spindle, and installed it on the right hand spindle of my axle at the top facing aft. I am now able to run my draglink from the stock pitman arm to that steering arm and keep it almost horizontal. Actually, with engine/trans and front end mounted, the draglink IS horizontal. The angle bar with the holes in the pix is the mock up draglink that I used to get a measurement for the real one and check for oilpan clearance.
