Hey guys....lowered the rear on my truck. unfortunately, I didn't relocate the shock mounts on the frame..thus, I have some shocks with an angle that I know will not function correctly ( or at all!)...does anyone know the correct angle? I will know gladly re locate the mounts on the frame and get correct length shocks. Thanks in advance.
There is no set angle, but vertical is the best, although I see very few that are vertical. Manufacturers say that zero to 30 degrees max.
They actually work much better upright unless they are gas, this will help you
