What do y'all think about the S-10 / S-15 4X4 8.5 rear ends? I have heard they are a pretty strong rear end & can take abuse. They are easy to find in any junk yard & are cheap & have a perfect track width. Also can find them with these ring gears, here are the RPO codes found in the glove compartment....
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
GV1 : AXLE REAR, 2.73 RATIO
GV2 : AXLE REAR, 5.83 RATIO
GV3 : AXLE REAR, 3.08 RATIO
GV4 : AXLE REAR, 3.36 RATIO
GV5 : AXLE REAR, 3.55 RATIO
GV7 : AXLE REAR, 4.11 RATIO
GV8 : AXLE REAR, 2.72 RATIO
GW2 : AXLE REAR, 2.56 RATIO
GW3 : AXLE REAR, 2.56 RATIO
GW4 : AXLE REAR, 3.31 RATIO
GW5 : AXLE REAR, 2.73 RATIO
GW6 : AXLE REAR, 3.27 RATIO
GW8 : AXLE REAR, 4.10 RATIO
GW9 : AXLE REAR, 2.93 RATIO (DUP WITH GU3)
G80 : AXLE POSITRACTION, LIMITED SLIP
