1 - 10 of 10 Posts
I also have a spool ,but I am reluctant to install it because I use the 39 mostly on the street.I heard the Detroit locker is stronger than the Powertrax. I was hoping that someone was using one and could coment ???
Im thinking of using a Powertrax unit in my 39 coupe. Right now it has a Ford 9in 28 spline open rear end. Has anyone used a Powertrax for drag racing?
Yes! I have had a Power Trax locker in my '71 Camaro for over 25 yrs. Lots of passes down the 1/4 mile, and many street miles also. I'm running it in a 8.5" 10 bolt, behind a 427 with TH350. Never had a single issue since I built this rearend. I'm running 3.42 gears, C clip eliminator kit, Dutchman axles.
Just watched Stacey David install one on the TV show called GEARS. It almost put itsef in. Looked so easy. Put it the side gears, C clip in (if they are used), put in the center units, add some small pins with springs after lining up the halves, drop in the passenger side C clip after lining up the slot for it, put in the center pin and bolt that in, rear cover, grease/gear oil, and your done. Mark L
We ran about 50 of those units in police training vehicles and they were tough,but they can be noisy and lock and unlock at times after they get some hard use. I had a spool in a Nova big block .Very dangerous in the wet almost wrecked the car a few times. Took it out after it pushed me into a curb and bent the front end and broke wheel. I am presently running a Speedway posi chunk in my Morris Minor works great,very quiet and easy to drive in the rain.
I've got about 22k miles on my blown sbc 41 Willys with a Detroit Locker. It works great. It drives both wheels except when cornering. then it tends to drive the inside wheel. It will squeel the big Hoosiers if I step on it too hard. It's like the noise police. haha Otherwise it works great rain or shine. I also have few miles on dirt roads.
I don't notice any noise in the car but some say they can hear it when I drive by slowly. It does have a bit of play as noted in the manual so it clunks going from forward to reverse and back again. I like to take the play out of it before stepping on it so it doesn't shock the tires and the rest of the driveline.
I have a PowerTrax locker in one of my Mustangs,with a 350ish hp 302 and a toploader 4-spd,and Mickey Thompson 26x10.5-15" ET Streets,which stick REALLY well.I couldn't be happier with it.Installation was not bad,and its proven to be bulletproof so far.....And I beat the heck outta that little car every time I take it out!:)
Scott
1 - 10 of 10 Posts
