1 - 15 of 15 Posts
My OG wants me to push I want her to pull. Seriously, Was thinking dump PL and going coilover w/push-pull steering for room. Dorset's are small. Looks like it would be more room. I know more complicate, but not really. Looked at a few old pix "now". Remember a lot of guys in the late '60s early '70s going that way. Maybe even earlier. A lot Austin's, Darts, and Opel's went that way. Kadette's and GT's were were real small but runnin' Hemi's. Any thoughts? Looking to run 472 or 500 Cad.
Discussion Starter · #2 ·
Also thought of going transverse.
Big caddy eng. start pushing the firewall back.... transverse can be done but you wont like being drug down the road like your in a shopping cart, and the cost and fab work is a lot of work and planing, coil overs will work and there is a lot of parts available, just remember nose heavy out of balance sucks no matter what
That's why big pipes with lead inside were made for rear bumpers! Showing my age?
Will post pix of steering soon. SCAREY!! Even for my old ass.
Firewall already gone. Most of floor also. Think car was an old Ohio gasser. still trying to find history. To much hacked out to be a fresh '80s build like I was told. But I Bought it anyway. Somebody has to recognize it from days of yore.
No reason a push/pull wont work as well as a transverse. Same rules apply, so still need to keep the drag link level, regardless of direction is travels. That's usually where the people going push/pull get into trouble. Because of steering box and frame interference, they often can't get the box low enough to allow the end of the pitman arm to be level with the arm on the backing plate, and end up with a downhill angle. But if you can situate your box and arm to maintain a level drag link, you should be good. The drag link is also much shorter on push/pull, vs. transverse, so being level becomes much more important!
My bad thought you where talking about putting a eldo drive train in as in transverse power train not steering steup
Discussion Starter · #9 · (Edited)
Big Cad. motor. Maybe 4speed. But little room in little car for stick shift. Transverse spring and hairpins. That's the reason for the ? push/pull.
It should have hit me between the eyes since I was considering doing the same thing but it looked really scary to me to
Check out Jim Oddy's car! Been runnin' transverse leaf w/hairpins for years. Check BOOBtube. Startup after 40 years W/Hemi old iron 392! Just punch his name on google. Will come up of all old and new pix.
Discussion Starter · #12 ·
Just likeyour car.
Why cant I find info or pix on coil over and hairpin straight axles? I know everybody wants to go pl, but looking for more room. An maybe lower the front.
Might search all those old 20's-30's Ford roadsters and coupes. They almost all use the system you're looking at, and no reason the same mounts wont work for your project.
Contact Don Waldron at Rods West in Ridgecrest, Calif. 760-375-4573. He has built many Austin Gassers and repo's the Don Long axles from the late 60s such as the setup used on Jr. Thompsons Austin. Go to austinworks.com website and you'll find some cool pictures of the car! Here's a picture of the front of the car in the pits, probably at Lions. http://www.austinworks.com/gp-jt3.jpg
1 - 15 of 15 Posts
