I have a few of these plastic Riviera wheels and thought I might put one in my '55.
This is how I fixed my aged and cracked steering wheel. This is the first time I’ve attempted to restore one. Having seen several wheels restored on the HAMB, I was thinking that this would be totally different because it’s plastic, not acrylic (or whatever older wheels were made of) and wasn’t sure what I would use to fix it.
The epoxy like JB seemed too hard and might have issues bonding to the soft plastic. Then I remembered fixing the rear bumper on my ’95 Roadmaster Wagon with a plastic ‘bondo’ that was flexible and bonded very well. So I am doing the same fix here.
The first thing to do was to de-grease the wheel. I used quick-prep but denatured alcohol should work just as well.
You can see that the wheel had come apart at the center pretty bad. I sanded under the part that is lifted to get all the rust and scale off, then quick cleaned it. I put a bunch of the filler into the gap and clamped it down to hold it tight until the filler hardened.
Each end of the center bar looked like this.
