1 - 11 of 11 Posts
Hey guys...removed a few rear springs and rotated the front leaf perches to get a 4inch drop to the rear of my truck ( this unit has the rear end mounted BELOW the springs). I n doing so, the pinion now has a positive angle of 10 degrees. i have heard that I should have a equal yet opposite angle of that of my motor/trans, which is at 3 degrees. With that , I am curious to how to remove 13 degrees. The only "wedges" I have found are for 2 or 4 degrees. Is this a "make my own" situation?..start stacking up the store bought? OR....start over and mount the rear end above the springs, thus creating a whole bunch of work, but being able to utilize a more conveinent approach. Any help here is GREATLY appreciated..thanks in advance
Summit has 6 degree shims, which should get you close enough. They are 2.5" wide, so if you've got narrower springs you'll need to just grind a notch in the sides with a grinder to clear the U bolts.
gonna have to purchase a digital to make sure..these things ARE hard to read...guessing 30.00 is not a bad price for accuracy and piece of mind.
I got one at Harbor freight. magnetic base. Worked fine.
1 - 11 of 11 Posts
