D/Gas, what are you using for a fuel pump? I have a Hilborn off of an early top fuel rail that I plan to use on my gasser. Front cover mounted, driven off the cam. I wondering how you are setting up your pump etc for the street with that mechanical injection. Are you using a small surge tank up front or pulling all the way from the rear? Info that you can relay will be much appreciated. I'm not using injection at this point but using it to fuel my blow thru carb. I will be running the pump into a bypass regualtor so the pump run at whayever it wants and let the bypass regulator control the pressure to the carb. I have plans to run some kind of an EFI in the future and hope that the same pump can supply that too??? Just not sure. Anywho, any thoughts that you may have would be appreciated. Oh, I do realize the pump is not made for an EFI situation since it can not preprime the EFI. I thought of using the pumps shutoff valve to run a small electric pump in the line and thru the shutoff to prime the system for start up and then switch over to the pump after firing. The carb is not a problem since it should have enough fuel in the bowls to run on until the pump is up to pressure. Mark L
