1 - 2 of 2 Posts
building a street Anglia what would be a good gauge metal.to use for the main floor pan. an also the firewall. not sure if I am going to mount brake booster on fire wall yet. thanks for any info,
18 ga. seems to be plenty heavy, and even 20 ga. if it's properly supported, or bead rolled to add strength. When I built my Austin gasser I used 20 ga. for everything, except the firewall. I went overboard on the firewall and made it from 16 ga., as I wanted it really ridged. But in hindsight I wish I'd done it in 18 ga. too, as with the offset in it for distributor clearance it would have been plenty stiff.
I used 20 ga. for all the firewall and tunnel on my Falcon gasser, and built a 1" box tubing frame to attach it to. It's extremely strong, and no flexing at all. The 1" tube makes a great support framework, and 20 ga. is plenty with the 1" tubing.
1 - 2 of 2 Posts
