1 - 2 of 2 Posts
Good morning all-Ive decided to step up the barn find 39 to a Richmond 4.11 gear but dont know wich one to get.They make 5 different 4.11s. The car will make 500 hp max and its for street-strip use. Can I get away with the standard gears or do I need to go to off road or racing? Its a blowm 350-turbo 350- Ford 9in. Thanks-Steve
If you read Richmond's specs you can probably rule out all the "Pro" gear serts. They are softer steel, and made strictly for drag racing and not designed to last for years of street driving. I would either go with the stock Richmond, or the "Sportsman" set if you want to move up slightly, but still work well on street/strip use.
1 - 2 of 2 Posts
