These are the best shots I can get of the car at the moment, it's angled in the garage so I can't bring it out on the drive while other work is being done and there's also two doors to the garage that blocks seeing most of the center out anyway. I hope these will be ok for now.
I cut the front panel and the grill as you can see and also had to trim the bracket that holds it all together and also holds the hood catch as well. The bracket has two bolts at the bottom, of which I cut the front holding bolt out and angled it back slightly with the grinder to allow the round contour of the tank, the whole lot is still very solid.
Wherever I've cut it I've rounded the corners and filed it so there are no sharp edges. Previously I welded a 2" x 1" box section across between the spring hangers, from this I will bend and shape two simple brackets that will hold it in place.
I always wanted to put a tank on the car but didn't like the idea of it stuck way out there in front, this way it hides it a little and doesn't look to bad I hope.
All the best,
Micky T.
P.S. Any pics that help make things easier are always gratefully recieved... Thanks!
