side pipes
Started on the brackets for the side pipes...just mocking up some front ones...I decided I would make some plates to fit under the pipes to cradle the pipes rather than hanging them from the back side...less chance of cracking at the pipe weld...you can not see them unless you are sitting on the ground in front of them...I decided to make them a little light weight...and use 3...and also add gussets where needed...rather than just throwing a big chunk of steel at them...wish I could find some cheap used running board rear brackets...would save a bunch of time...also have to decide if I want the pipes to hang out like the first pic in my other post about them....( just for you Mario] or the one here with them tucked in.....?
