And... I hate to be a bearer of bad news, and I'm not trying to sound like Mr. knowitall. BUT.... you need to run that tie rod BEHIND the axle. I noticed in your pic it looked like it was in front, that's why I asked. Hopefully you are still mocking stuff up and haven't committed a bunch of fab work to this setup yet. If you run it in front with those steering arms, your ackerman will be all messed up.
A brief explanation - The distance between the tie rod holes is LESS than the distance between your kingpins. If the steering tie rod is located behind the axle, draw an imaginary line from your kingpin to the tie rid end on each side, those imaginary lines should intersect somewhere right around the 3rd member on your rear axle. This helps the car turn correctly.
If you mount that tie rod in front, draw those imaginary lines again. The lines will splay out somewhere OUTSIDE the rear wheels. No good. There are specific steering arms to use the tie rod in front of the axle, but on those the distance of the tie rod holes is GREATER than the distance between king pins.It's a safety and driveability issue.
Again, I am meaning to be helpful not critical. That's what we are here for.
Here are a couple pics to help explain, Maybe google "ackerman steering" to do a little research. And I am going to put a thread linked here in the steering section so we can all help you out.
