You can install any 4 series ring gear in a 3 series carrier if you buy the ring gear spacer kit. It comes with the spacer and longer special bolts to accomodate the spacer. I'm running a 10 bolt GM, but also used a spacer to go from 2 series to 3.73 gears. They are still available for the '55-'64 carriers if you decide to go that route.
