1 - 1 of 1 Posts
Vall, here's what I found out with the 1 1/4 G.L punch. We took a piece of 18 gauge mild steel, punched an 1 1/4 hole and then used a Mittler flare die that would fit the best, which turns out to be 1 1/2 flare. The flare did the job, however it did not produce the same flared edge that the Mittler punch and flare die did.
Here's the difference between the two.
Clearly you can see the difference in the depth of the two dies.
1 - 1 of 1 Posts
