1 - 3 of 3 Posts
Hello Fellow Hotrodders
Need help to ID this axle on my 57 chevy car for a disc brake kit, supposed to be a Dodge axle, they have three different types from what I've been told. Possible 60's Dodge Van A-100. Here are some measurements, 49" between King Pins, 32" between center spring pads, 2 1/2" springs, 5 on 4 1/2" lug pattern. Thanks for your help.
Pete Go to Nostalgia Sids axles website he lists all the specs and cast #'s Lash
Whoever told you it might be an A100 axle was correct! It's got all the markings, and configuration of an A100. Here's a breakdown for the A100, which you can compare to see it definitely looks like your axle:
Notice the little triangle shapes inside the I beam at the curve of the drop. Also the shock mounting location. The wide 2.5" spring also.
1 - 3 of 3 Posts
