Sounds pretty much like a vast majority of gassers. There is a point when a gasser stance gets high enough all around that it reaches "street freak" status. It's that old saying, "I know when I see it, but can't tell you what it is."
If you go high enough, you'll know when there's too much space between the tires and the body, and you've reached street freak status. I personally like gassers a little higher than some traditional gassers look. But just not so high that I need a step, or a handle to help me enter the car. Usually if the bottom of the rocker is a little above wheel center, or slightly higher than the center of the wheels, it looks good to my eye.
I've seen some where the wheelwells are so far above the tires that they look more like 4WD's than gassers. Handling can get pretty scary once they get that high, and body roll is a real problem too.
