Thank you Mario, but the PRO remains in the name...... I'm still on my learning venture in the hot rod builder world..
but nothing better then a bunch of good old hot rod folks to help figure out what's works best for each individuals ride.
My thought on front spring is one I like the shackles up front, but have not shown any baring on ether front or back. However when it comes to angle, it may be a more scientific then we think. Angle seems to affect a few things, one being spring weight, the other articulation. I think both are important were they can or may lead to a better/safer ride quality.
I like past ninety degrees forward, when the shackles are mounted front or rear.
My thoughts if you start off the shackle in the direction it's going to swing there's less stress when the spring pushes the shackle threw its arc. Now when the vehicle lifts, the shackle will want to come back to ninety but with no chance to swing negative. So some applications may take more forward angle then others. So we most likely have to keep the shackle from going to far forward hitting or bottoming out on the frame and when spring unloads, not swinging to a negative arch stressing the shackle to return to its curb position.
I'm not sure how one would calculate at what point in the arc what the spring weight is. Think of all the variables, that would affect this. Weight of vehicle, motor location, curb stance, shackle location, and length, shock length, and the list goes on.
I like to tack the the shackle mounts in place and try to simulate different scenarios with tie down straps and jacks for load and unload.
I guess what I'm saying, short of sounding like a politician that had said a lot with out giving a direct answer
we can trail and error, follow what works for others with a similar application, and post questions, pictures, and share your results.
