I've decided to swap cams in the 327 in my Austin, as it's just not a good low to mid range cam. The cam I'm taking out is a hydraulic flat tappet, and specs are duration 234/234 at 050" lift, with 488/488 lift. Advertised duration is 292/292. LSA is 114.
This is a high rpm cam designed for 2800-6500 rpm power range. It's got breakin and less than 1,000 miles on it. Anyone wants it for just shipping, it's their's. Hate to just toss it in the scrap when I put the new cam in.
I'm going to put the Isky 270 cam in with 270/270 duration, 465" lift, and 108 LSA. Should have a lot more low end power for the kind of use my car needs. I'm using 1.6 ratio roller rockers, so my lift will be a bit higher than that advertised with stock 1.5 rockers.
