1 - 20 of 33 Posts
Finally got the car painted! Didn't get crazy with body work, left some highs, lows and waves here and there.. Painted her gasser green with a satin finish clear coat... Now on to assembly :+1:
I am just a guy who will always be a kid at heart, especially regarding gasser hot rods. Will this be a street driven car with an occasional trip to the drags. I agree with Vall, can not tell what engine is in just makes me scratch my head:confused...I love your ford!... now that the good weather is in, time to get back on my 37 in my garage just waiting for me to get it restarted.
It's a 468 big block chevy, rectangle port heads, 10.75.1 comp , .648 lift comp solid flat tappet cam .. Stock rods, ARP bolts , speed pro Pistons.. Rearend is a 9" ford, strange 31 spline axles, Detroit locker, I'm running a Chrysler A833 4speed trans modified by liberty with a Mr Gasket V gate shifter... Just a bunch of stuff I had or friends had laying around.. It's just something I can drive to work, the hardware store or cruise night.. I will race the car periodically but it was built just to drive around on the street... Thanks guys
I'm using a speedway front axle kit, I used the frame rails that were stock formed in with the old strut towers but I trimmed the sheet metal away... I put a crossmember in the rear and tied a set of 2x3 frame rails into the stock front rails for strength
That's a good looking ride. I've got an 8 3/4" Mopar housing running 4:56 gears in my 53 and when I was debating what I wanted for innards, a locker or full spool, Money ended up being the deciding factor; so a spool it was. Decades later it's still in there and no broken axles; I just don't go fast around turns. It's funny too, because now that I have the money to go with a locker I figure "what for". I'll wait till I break something...........
Thanks for the details! Sounds like a great combination, and I love that it will be driven to street events, and fun driving!
A little more progress.... Front axle and steering is chromed, motor, trans and shifter are in, rear end is in, I built a 12 gallon fuel cell, mounted fuel pump,fuel lines are in and seats are upholstered...still a ways to go but I'm getting antsy!
Discussion Starter · #14 ·
I ran into issues with the factory steering column, the upper bearing was wore out, the wiring was butchered up and it was originally a automatic car so it had the gear selector and the shift lever on it... After I had it painted and tried to locate a 4speed top collar pc, wiring and a bearing I was frustrated... So I got a pc of 2 1/4" aluminum tube and some 2 1/4" bar stock.. I machined some bushings so I could use the stock steering shaft in the aluminum tube that way I could utilize the rag joint on the steering box and the steering wheel adapter that I had already purchased... About 30 min on the lathe and $10.00 for the tubing I have a new column
Discussion Starter · #15 ·
Not sure if any of you fellow hot rodders ever ran into this issue... I could not find tail light lenses to save my life, I'd get out bid on E bay, I'd call around trying to find re manufactured lenses.. No luck, I tried swap meets, I had no luck.. So, I went to a local plastics shop and picked up some transparent red lexan and a pc of ribbed / clear pc, traced the remains of my old lense, cut and drilled the bolt holes.. And I made myself tail light lenses... They aren't as cool as the factory bullet lenses but I made these for $12.00.. Sometimes you gotta get crafty ..
Wow! The Fairlane looks like a great looking car, and nicely done! I love making little parts and pieces, and I think your taillight lens is even nicer than the original! Nobody will ever wonder why you made them, they'll just want some too!
Its hard to type when your jaw is hanging slack and you cant take your eyes off the pictures! I cant wait to hear it run. Just beautiful...
1 - 20 of 33 Posts
