Also, check to make sure that your secondaries are completely closed at an idle. If either carb has a secondary butterfly that is somehow being held open, even a little, it will increase your idle. Double check the vacuum line going to your distributor again. If it's getting vacuum at an idle it'll advance your idle exponentially depending on how much vacuum it's getting. Getting back to basics, did you back off completely the idle screw of both carbs and not just one. Did you check both of your power valves to make sure they weren't blown; if one or both are, that means the motor is sucking in excess fuel. If your motor has backfired there's a good chance you've blown one or both power valves unless the carbs are newer and came equipped with the factory anti blowout valves or the guy you bought them from installed the after market kits. The easiest way to check, for me anyway, is to pull them out, put the end opposite the end with the spring to your lips and suck. If the diaphragm isn't blown the spring end should be drawn in, if not that's a good indication of a blown power valve. We've suggested looking at the vacuum rating on the power valve body. If with your cam you're only getting say 6 inches of vacuum at an idle and your power valves are rated at say 8 inches or more you're going to have fuel being drawn into your motor. There's a formula for figuring the correct power valve. With your motor warmed up and at curb idle check your manifold (full) vacuum. Say it's 5 inches, I believe you're supposed to go to a power valve rated at about 2.5 to 3 inches.
