Simply turn your steering box left or right until it stops. Mark the position, and then turn it the opposite direction and mark the position. Then turn it halfway, and install the pitman arm at that point with your wheels perfectly straight. This will ensure your steering box is in the neutral centered position. If you are not centered in the steering box you'll cause the box to wear out prematurely, plus have the issue you have now where it turns farther one direction than the other.
