1 - 1 of 1 Posts
This is just an idea that I was playing with so its a rough design idea, it would be a cradle for the front axle mount, on my NOS ranger it would fit under the frame horns and would bolt on using existing bolt holes in the frame bottom witch is 1/4 thick, it would span across from one horn to the other spring extension boxes could then be welded to the bottom of the L brackets and either a u shaped perch bracket or a piece of tube welded thru the extension to mount the perch to, the weight of the frame would be in the L bracket saddles with in turn would be supported by the springs, pipe across would be to distribute the lateral forces to both the frame sides, no welding on frame there are 6 3/8 bolt holes 3 each side 2 where for the sway bar and one for ???
1 - 1 of 1 Posts
