IMO, and those of a couple reputable engine builders I do some business with, nothing but a "poser" cam. The rumpity rump comes from the timing of the valve opening and closing and the duration... I usually go with a custom grind that the cam company's tech guys suggest. I'm more concerned with the acutual performance of the car then the sound of the engine. Being fast and sounding fast is seldome the same cam. Guess it all depends on what your priorities are for the build!!!!!
Another item of interest that most all the engine builders are saying now is to run a roller cam, hydraulic roller for the street, mechanical roller for racing, as the oil we get now doesn't have the right chemical compisition of ZDDP to make a flat tappet cam last. Seen lots of flat tappets go bad in the last few years, I run rollers in everything now with no problems. Performance is a lot better with the faster and steeper ramp rates with the rollers, too.
