Lets see what you all have done to limit turning on a straight axle setup with chevy spindles. Have mine mocked up .I would like to install stops. Thanks Dale
BTTT
What have you all done to add a bump stop to your straight axles..I don' t want to weld on my steering arms!
My Falcon uses a factory E100 axle, so has stops. My Austin doesn't have stops, and the only time it's been an issue was when I was trying to turn sharp out of a parking spot, and I turned too far. It started pushing the front tires, and I had to straighten the wheel a little to avoid sliding the tires.
I've never needed steering stops, bump stops are for suspension
