Cragars were my my second favorite wheel after the Torque Thrust followed in 3rd place with slots.The Cragars were as classic as anything, but Torq Thrust equally classic.
Thank you. I don't have a plan yet on how to apply that gold on the door panels, but I'll give it some thought and see if I can come up with something. Maybe an insert in the door panel? If I do anything it needs to look intentional, not an afterthought.I really like the look of the dash after you finished. The gold metal turned pattern sets it off. Are you planning to continue the gold design into the door panels? Keep up the good work, I am sure your Dad is going to be proud to get this!
re: disc- yes, I had to bore out the center hole slightly to fit my axles. they had slightly larger flanges that these discs wouldn't clear. I was forewarned in the instructions, too, ha ha. It was very minor, though, not even enough to completely remove the chamfer that came on them.Those door panels and rear panels look awesome! Also, just curious, on your lathe, are you turning down the inside lip of of the disc to fit your spindle? Have fun.
