1 - 15 of 15 Posts
I just bought a 65 Comet and want to build a gasser.
Does anybody have any good build treads comet/fairlane?
Where is the best place to get a front suspention? speedway?
Looks like the speedway springs are short and look like that it mite ride bad. Any info on that? thanks
Welcome to the forum. 65 Comets make great gassers. You can get the axle from speedway or a multitude of older trucks. I am going with a late 40's to 50 dodge truck axle on my 66 Falcon. Speedway axle setup is more complete and all brand new. When I convert my axle to disc brakes it will only be about 150-200 dollars cheaper than the speedway kit but I like to abuse myself and do it the harder way. There are a few build threads of falcons and comets in here to pull ideas from. I am not sure about the ride of the springs.
If you can find one, I'd drop a early Econoline straight axle into the Comet. Should be a good width, plus it will be all Ford and keep the original bolt pattern. Probably cheaper and easier than a Speedway axle too. I see them around $250 occasionally, and I bought one a couple months ago for $120 with all new drums, kinpins, rod ends, etc. and it had original springs and shackles too.
I'm not familiar with the Comet setup, so I can't answer that question. I know the Econoline is a push/pull steering, but that's an easy swap to make them cross steer. Depends on how your pitman arm lines up with the axle and tierod assembly.
Hello and Welcome to the forum! Yes you can use stock steering box in its stock location. On my 64 Falcon were running a 65 Ford econoline front axle that has been narrowed. The steering has been changed to cross steer using a dropped pitman arm. The front econoline springs and brakes were used, rides and stops very nice.
Gary
Welcome aboard and glad to see all the Blue Oval guys piping in on their setups. Maybe we can figure out a way to make tech articles for each style of car with measurements and recommendations. That sounds like work... :D
You don't necessarily need a dropped pitman arm. You can put the steering bracket on the top two bolts of the spindle, which will make it line up closer, and probably not require a dropped pitman arm. Usually just takes longer bolts and a couple spacers to mount it.
after trying out several differnt boxes on my 55 i used i steering box out off a 2000 ford expedition its fairly small and worked nice and i had power steering
I used a steering gear from a 63 Galaxy on my 67 Falcon with Econoline axle converted to cross steer. The main reason I changed from stock was because this gear uses a rag joint and allowed me to drop the colume and extend the shaft back some, I used a colume shaft from a early seventies F100 pickup.
1 - 15 of 15 Posts
