Wick, cool looking truck. What kind of running gear have you got n there?
Andy
Andy
does anyone have advice on how to go about doing a front end lift on my stock i-beam 3-5 inchesWick-cool truck,lots of patina.I also have a 55 3200 stock hight truck that I am thinking of giving the gasser look. Its so easy to do-just block up the front end a few ins and thats it.I also like to tilt the kingpins back a few degrees for more steering stability. Nothing worse than a poor handling I beam! Good luck with the build-post pics!
Easiest/cheapest way is to have new springs made with more arc, but the same length. So the spring maker will have to make them longer as the arc gets greater. You can also put spring perch blocks inbetween the axle and the spring to raise it, and get longer U bolts to clamp it. I wouldn't go more than 3" with blocks.does anyone have advice on how to go about doing a front end lift on my stock i-beam 3-5 inches
