Found a nice gen 6 eng, going to do a 489 or 496. Does anyone have a solution for the high dollar lifters? They are a roller block, they say you can't use the stk type hyd rollers with a small base circle performance cam, found Crane's, $900. What's everyone doing when they are using these blocks?
Look into getting your cam hardface welded and reground to your specs there is not much out there past gen-V and those will run you $450 or more
Always had early BBC's, so not sure I'd want to hassle with a Gen 6 unless it was good enough, and cheap enough to cover the extra cost.
:eek:HOLY CRAP! My Cad is gunna be less.
