My very first thought was that the lines are probably made in China from what is probably inferior material.Yesterday on the way to the car show I was cruising down the freeway about halfway to the show and all of a sudden there was a big dip in the freeway! I hit it hard as I didn't have time to hit the brakes when I saw it. I slowed down and everything seemed OK, but a short time after I began to smell raw gas! I pulled over to check my entire fuel line from tank to carb, but all of it was secure and dry. So drove on to the show, and did the hill climb, and 100 mile run home. But always smelling the raw unburnt gas smell.
So today I was washing all the bugs off the car, and cleaning underneath, and hoped I'd see something, but still all dry. Then I had the light go off in my brain, and I said to myself, better check the vent. I built a cover over the vent and fuel sender to protect them from damage from anything I put in the trunk. So unscrewed the cover and set it aside. Sure enough the 3/8 hard line into the vent was snapped off right at the fitting! Easy fix, as I just dressed the end, slid the fitting over it, and put a new flare on the end. I added a rubber pad under the horizontal part of the line between the tank and the exit through the floor, just incase it might have vibrated at all in the 10" section. Sure glad I found it and it was an easy fix so I don't have to smell gas and wonder when it might ignite! But can't figure out how a well secured line could fracture, and snap clean off, even with multiple big bumps?
