I swear to God I'm getting senile! After taking my brake lines apart and replumbing them to install the line lock, I got back today to just bleed the brakes. I'm gathering my vacuum pump, and tools, and laying things on the front fender. I suddenly look down and it hits me that I plumbed the line lock into the line going to my proportional valve! The same prop valve that goes to the REAR BRAKES! What an idiot!
So had to remove all the plumbed lines, repipe the line to the proportional valve, then take the front line off, and make up new lines to plumb the line lock back into the front brakes. Of course the only parts I could reuse were the fittings, as none of the lines were correct anymore. Had one line I could shorten and rebend, and swap one end fitting, but otherwise it all had to be redone.
So after several hours of work and $8 worth of new line, I finally got back to bleeding the system, and finished. Sometimes I wonder how my mind works to end up piping a line lock into the rear brakes? Or I guess it just wasn't working. At least I didn't have to bleed it twice, or figure it out when I tried to use it!
