I posted some info when I introduced myself but thought I would post some updates and additional info. I am building a 1950 Stude 2 door sedan (circa 1965). I am going to run a 56 Olds rocket taken out to 346ci with 10 to 1 compression and a Isky 505c roller cam. I am using a Joe Hunt magneto and a Weiand tripower with J2 carbs on it. I am running a M21 with a super comp shifter. I just installed a 8 3/4 mopar read axle and will be setting up a 489 case with 4.56 posi. I have a set of 30 x 10 hurst cheater slicks. I am using the original rear leaf springs with a pinion snubber and a set of traction master's. on the fron I am using a model a axle and travers leaf spring with lincoln brakes.
