I am still mapping out the headliner screws and I needed to place the radio box back in where it was mounted to place the wire harness and antenna lead through either the headliner or the header panel. I cut out the header panel from my template and checked the fit. Made a few trim cuts for a better fit. For now I made cut outs at the top of the header panel for the antenna and wire harness cause Im still not sure where it all will fall in place yet. I will confess to you guys, just don't tell anyone, that I have a slight shortage at the passenger back area. I am going to try to pad the frame and wrap around the side header panel a little higher than I originally wanted to. Yes guys, Its another snaffoo!. I placed the dome light back in and the front header panel for a fit check before I glue the vinyl to it. I also checked the dome light to make sure it works right.
