41 Willys Pick up - Page 2
Page 2 of 41 FirstFirst 123412 ... LastLast
Results 11 to 20 of 402
Thread: 41 Willys Pick up
  1. #11
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    1,732
    Fuel, Water, and Oil
    Well, I think I'm about ready to try starting the motor. Since I didn't build it I'm hopping the guy who did knew what he was doing. Supposedly it was freshly built and balanced but there was no paper work to substantiate that. I pulled the plugs out to squirt a little oil in the cylinders and if the plugs are from this motor it all looks good. Just need to fill all the necessary fluids; pull the distributor to prime and check for oil pressure and hopefully it'll start.
    I'm done for the day; probably get to it one day this week after work.
    Steve Hidden Content in sunny So Cal
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #12
    Senior Member Beer:30's Avatar
    Join Date
    Dec 2011
    Location
    Temecula, Ca
    Posts
    354
    Looking good Steve. You're still getting this together to sell? Careful there after it's running you may fall in love and need to keep it! Hope the engine work the other guy did was solid and everything goes smoothly. Best luck
    Hidden Content Thanks, Craig
  4. #13
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,323
    Good luck Steve! Hope it is as good as promised!
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #14
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,062
    Steve can you get in there and prime the oil pump...if you dont have one I think I have one that works off of a drill some where in my stuff, that is low profile
    Lash
  7. #15
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    1,732
    Lash, I think I'll be able to get my primer tool in there and use my 90 degree 3/8 drill to spin it; thanks for the offer though.
  8. #16
    Join Date
    Dec 2012
    Location
    Long Island, NY
    Posts
    6,632
    That's a cool project steve. I wish you well with it. Hope all goes your way with getting it together.
  9. #17
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    1,732
    I'm leaving for a weeks vacation today, in about 3 hours. I told myself I was going to get the Willys fired up and the wheels going around before I left. Yesterday I cancelled my clients to get it done. I double checked everything, filled the trans, pulled the distributor, primed the motor until I was getting oil to all rockers, dropped the distributor back in, gave it some advance, turned on the fuel pump, (fully expecting several leaks from the long sitting Holley carb), checked the float level and hit it. Fired right up. Sounds great, 60 psi oil pressure at 1500 RPM, 175 degree water temp, and no leaks. Man I'm going to hate selling this. I'll post a video when I'm back next weekend.
  10. #18
    Senior Member
    Join Date
    Feb 2016
    Location
    South Central PA
    Posts
    258
    Awesome Steve! Glad it went well for you! Enjoy your vacation! Gotta love that SoCal weather! Sure looks better than 50's and rain here.
    Lon
  11. #19
    Join Date
    Dec 2012
    Location
    Long Island, NY
    Posts
    6,632
    That's great Steve. Now you can feel accomplished. Glad you didn't get stuck with a basket case project. I bet you will be sad to let it go.
  12. #20
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,323
    That's great news Steve! Glad it went so well, but I'm sure it will be a little sad when it leaves!
  13. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
