Made some progress - Page 3
Page 3 of 133 FirstFirst 123451353103 ... LastLast
Results 21 to 30 of 1322
Thread: Made some progress
  1. #21
    Senior Member Tommy Boy's Avatar
    Join Date
    Feb 2014
    Location
    Massachusetts
    Posts
    203
    It kind of looks the toughest slung low like it is in your very first photo in the thread. High up like that, it looks somehow fragile like it wouldn't really function correctly mounted to a flimsy tail gate.
    Way down low, as in the first pic, it seems like there might be some additional mounting bracing going on behind the valance/attached to the push bar, you know? Just looks tough down there.
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #22
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,058
    Another way
    I can do this I just have to make it a double quick release and remove to open tail gate would not have to mod what I have????? keep in mind the bag only holds the chute, the chute is really attached to the balance point off the frame
    Lash
  4. #23
    Join Date
    Dec 2012
    Location
    Long Island, NY
    Posts
    6,619
    I agree with Gary on placing it under the lettering. Kinda fits there. But whatever you choose will be fine.
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #24
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,058
    Thanks guys, I just have not had that lighting bolt strike to the head that i usually get. I know its a small thing but its hard to get a classic look out of something thats not a classic... so the little stuff matters more... I may have to do a temp set up cause I need to get the bumper coated with bedliner cause rain is on the way then cold weather, need at least 70 degrees to do it outside it really stinks, I like it under the lettering also I think I need a smaller light though
    Lash
  7. #25
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,307
    Have you looked at moving it further under the truck, so the plate is still visible, but not "in your face" as it is in these three choices? It looks like a centerpiece up high, and most other places it detracts from the whole rear view. I'd either mount it under the truck back in a foot behind the bumper, or choose the lower left bumper, if it has to be out farther.
  8. #26
    Senior Member noted1017's Avatar
    Join Date
    Sep 2013
    Location
    TEXAS
    Posts
    596
    howdy Lash I agree with Vall and mount it on the lower left bumper
  9. #27
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,058
    Well these showed up at my door today not real happy with them they look great but the mounting surface area is lacking....only about 2/3 of the outer face of the rim surface area touches the rotor face, its the 1/3" raised area on the outer edge, then in the inner there is a bevel part that has a surface area on about .020 ths. no where do the lugs put pressure on the rotor face they stress the center of the wheel at the to contact points, Iam thinking these need to go back to summit racing
    Lash
  10. #28
    Senior Member maddog3299's Avatar
    Join Date
    Jan 2011
    Location
    Washington state
    Posts
    1,411
    I haven't tried any of the rocket wheels, but that sure doesn't look right or safe.
  11. #29
    Senior Member Warlock's Avatar
    Join Date
    Jun 2015
    Location
    San Antonio
    Posts
    278
    Quote Originally Posted by Road Angels View Post
    That's to bad, they really look good.
  12. #30
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,307
    I've never seen the back side of the Rocket wheels. That doesn't look good to me either! ET Gasser that is much nicer design, and mounting. About $10 more per wheel, but well worth the extra money!
    http://www.ebay.com/itm/Team-III-Gas...pVwT1d&vxp=mtr
  13. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
