Made some progress - Page 148
Page 148 of 152 FirstFirst ... 4898138146147148149150 ... LastLast
Results 1,471 to 1,480 of 1512
Thread: Made some progress
  1. #1471
    NY
    6,979
    Agreed, and don’t you have the motor and trans out of the truck? I’m thinking When it all settles the axle will have to be Re-centered again no?
  3. #1472
    3,305
    Rainbow Bridge
    was wondering of it would show so I had to try it
  4. #1473
    12,767
    Lash, you swap axles like I change socks! Must be the attraction for the transverse spring axles you have!
  5. #1474
    3,305
    At least every one knows you have clean socks on all the time.........lol
  6. #1475
    3,305
    Had to play around
    Was to nice out not to .....
  7. #1476
    12,767
    Looks great!
  8. #1477
    NY
    6,979
    That looks hot. When the motor sets it down slightly it will be even hotter.
  9. #1478
    NY
    6,979
    Hey Lash. Look what popped up on Facebook.
    https://m.facebook.com/marketplace/i...Anull%7D%22%7D
  10. #1479
    3,305
    Thanks guys...but to be honest I am not in love with the way I did it...I should have made the scoop bubble sit level and not slopped following the hood line, plus I should have done the same with the paint top line on the bubble
  11. #1480
    3,305
    Almost pulled the trigger
    on lowering the truck down on the frame by cutting the lift spacers...down to 1" from 3"'s so I spent some time making a list of every thing that I would have to do to achieve this...well the list was long remake bumper brackets front and rear, pull filler neck from tank and shorten it, remove the seats, pull up sill plates and kick panels to remove carpet, lift cab and bed to replace body puck spacers,,but the deal breaker was to have to pull the bed all
    the way off so I can flip the leaf spring hangers back over in the back,they would hit the bottom of the bed if not flipped back..it is to damn cold out to do that one...then after really looking at it I realized that it appears much higher in pics due to the fact it is sitting on an uphill grade when in my drive way...so I think I am going to lift the back up by going one hole down on my rear shackles...and see how that looks...it is getting short on pictures here so here are some
    Attached Thumbnails Attached Thumbnails shop view 001.jpg   shop view 005.jpg   lower 004.jpg
