Made some progress - Page 146
Page 146 of 148 FirstFirst ... 4696136144145146147148 LastLast
Results 1,451 to 1,460 of 1471
Thread: Made some progress
  1. #1451
    12,667
    What good is an I beam axle without holes?
  3. #1452
    3,239
    Axle
    Clean enough for paint starting with using my 5 left over 1/4 full self etching primer cans....you know the cans that will only spray vertical cause there 1/4 full...time to clear the paint shelf of all the ones you saved.....yea a budget job
  4. #1453
    Member fiftythreechevy's Avatar
    Jul 2018
    Washington State
    47
    Looks great Lash. Are you going with the holes or no holes on the axle? You're paintjob looks great too. My friend and I are going to try to lace my top once it's ready for paint, will be the first time for both of us.
    Nick
    There was never a horse that couldn't be rode, there was never a cowboy that couldn't be throwed.
  5. #1454
    3,239
    Nick I decided not to do the holes...the biggest I can go on them is 7/8" with out going into the bottom of the beam top...looked on line at some and they just did not look right....too small....1-1/8 would have been perfect...but would be to far into the structure...the transverse axle is about 60% lighter than a parallel spring axle, if not more...I am working on an idea to solve that problem, I hope
  6. #1455
    3,239
    In the end
    What really matters...is you get it done...first was going to do holes...too small wont work for me then the idea of a fillet plate at the front with holes drilled in it and then polished...could not find the right size to fit in to the recess part of the beam...so I will just paint it...well did not have enough of one color to do the whole thing...sssooooo....two tone was the option of the day...does not show but I also sprayed on some duplicolor effects looks great in person but does not show in the pic...I used up 8 cans of near empty spray bombs
    Attached Thumbnails Attached Thumbnails painted 2 tone 001.jpg   painted 2 tone 004.jpg   painted 2 tone 003.jpg
  7. #1456
    12,667
    Green and blue, with a fade? Or is the blue just masking tape?
  8. #1457
    1,899
    Hell
    I thought maybe the Holenator was going with a theme in support of the Rainbow Coalition, LOLLLLLLL!!!!!!!!!!!!!!!!!!!!
  9. #1458
    12,667
    I always use a half inch holesaw for electrical work, which has an actual diameter of 7/8". So I like that size myself.
  10. #1459
    12,667
  11. #1460
    Jul 2018
    Washington State
    47
    Vall, I do like the look of the holes as well!!! I have contemplated them for my build, but my car is heavy and the big block is heavy as well. I might get away with them yet.
    I must say however, the two tone paint may start a new trend!
    Nick
