T-10 to 460
Results 1 to 7 of 7
Thread: T-10 to 460
  1. #1
    T-10 to 460
    I have a Borg Warner T-10 4 speed from a smallblock Mustang. Will it fit behind a 460?
    David
  3. #2
    3,392
    The trans will work...you need the right bell housing ...351M to 400...depending on the year of the 460...internal balanced...or external balanced for flywheel...you can not mix the parts
  4. #3
    12,911
    Real question is will it hold up to the torque of a big old 460?
  6. #4
    2,001
    Same
    thing I was thinking Vall. Probably a Super T-10 or Muncie M-22 would be more appropriate but they're big dollars, $2000 or more and then there's the linkage.
  7. #5
    12,911
    If he's got linkage, I think a Super T10 will use the same? And those two trans would both be better behind a 460 Ford. Of course the Muncie M22 is the king, but even more money than the Super T10.
  8. #6
    3,392
    should not be a problem strength wise since it is going into a gutted out falcon...in a heavy car it is not enough...before I spend the money on a Muncie or a super T10... I would look for a 5 speed, used after markets are out there for good prices
  9. #7
    I figure since I can't fit a bunch of tire under the lightweight Falcon the T-10 will probably live a while. Besides I am not hard on parts. I had the flywheel balanced with the engine parts. Thanks
    David
  10. Remove Advertisements
