Brake drums for a 58 Olds rear
Results 1 to 4 of 4
Thread: Brake drums for a 58 Olds rear
  1. #1
    Junior Member TNBandit's Avatar
    Join Date
    Oct 2020
    Location
    East Tennessee
    Posts
    13
    Off the wall question but the 57-64 Olds rear ends were a very popular swap for gassers back in the day. My 36 Chevy 5 window coupe has one. I've got all the parts gathered to rebuild it and a set of 4.10 gears to replace the pitted 5.38s that were in it. The last thing I need to locate is a pair of brake drums. I've read somewhere that certain years of Chevy 1/2 ton 2 wheel drive drums fit but can't verify. All sources I've checked have no listing other than Fabcraft and they are pretty proud of their stuff. Can any of you old timers who ran these rear ends offer any advice ? They are 11x2 with a 5" bolt circle.
    General, Pharoahs Car Club, Tennessee Chapter
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #2
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,770
    I can tell you that the only years Chevy used a 5x5" bolt pattern was in the Chevy trucks from around 1975 to maybe 1986. So if there's a chance to find an 11" x 2" drum that interchanges it would be those years. Those were 11"x2" drums, but can't say if they'll be a perfect fit or not?
    If it were mine I'd simply go to one of the local chain stores and buy one drum, regardless of price, and take it home to check fit. If it works you can decide to buy a 2nd drum, or take it back and buy a pair of the same somewhere else if that's cheaper.
  4. #3
    Join Date
    Oct 2020
    Location
    East Tennessee
    Posts
    13
    Quote Originally Posted by 1946Austin View Post
    Well now, don't I feel stupid.. As soon as I finish installing the 4.10 gear set and putting the axles back in maybe I should just jack up the 74 C10 that's sitting right beside it in the shop and try on one of those drums.. lol
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #4
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,770
    It might be the same, but not sure? I've got a '69 Suburban, and it's been converted to later 5x5" drums, and spindles. Not sure if pre '76 are the same? Of curse if yours does fit, then you've got the answer on what to buy.
  7. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
