Front Axles
Results 1 to 8 of 8
Thread: Front Axles
  1. #1
    Front Axles
    Has any one used a Cherokee front axle for a gasser build I mean they are cheap and have disc brake's on them and pretty light
    Sent from my SM-N960U using Tapatalk
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #2
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,915
    I haven't but have a friend who did use one, and I've seen a couple others.
    They are somewhat light tubes, but the assemblies at the spindles are much larger, and heavier than traditional spindles. Not especially pretty at those ends either. But for a budget build, they can be a decent option.
    I see them for around $75-$100 around my area, and a decent I beam from a truck runs $100-$125, so not a huge savings. I personally would prefer a pickup, or van I beam axle for looks.
  4. #3
    I have both just thought of the disc brakes in them but figured they might be ugly but I an just building a driver I grew up in the gasser era and always thought they were cool thanks for the info
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #4
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    2,006
    My cousin
    used a Jeep tube axle on his blown 524 inch Cadillac powered 54 Buick gasser. These aren't the best photos but they're the best I have. I personally don't think it looks that bad.
    Click image for larger version.
ID:	104371 Click image for larger version.
ID:	104373 Click image for larger version.
Name:	54 Gaser1.jpg
ID:	104375 Click image for larger version.
ID:	104377 Click image for larger version.
Name:	Mark and Buick.jpg
    Steve Hidden Content MOB in sunny So Cal
  7. #5
    Wow thanks for the pictures I would like more information on the build if I can get it as I have never attempted this before
    Sent from my iPhone using Tapatalk
  8. #6
    Join Date
    Feb 2012
    Location
    So.Cal.
    Posts
    2,006
    Here you
    are Alan. My cousin, like you, wanted something with disc brakes already included. He also liked the straight tube axle set up on my Willys vs. the I beam on my 53. He went to the wrecking yard and got his axle off a Jeep that was wide enough for his application. Then he cut the front end off the Buick and boxed it for the correct width of the leaf spring mounts from the Jeep axle.
  9. #7
    Sorry just now getting back on here life happened anyway how did it turn out any pictures ??
  10. #8
    Join Date
    Dec 2012
    Location
    NY
    Posts
    7,101
    Hey Steve your cousins Buick is Bitchin. So cool. Unique too. Love the Cadillac mill too.
  11. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
