1941 willy coupe from uk
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 1941 willy coupe from uk
  1. #1
    Junior Member WW58Bandit's Avatar
    Nov 2020
    10
    Hello all here is my project, me and my wife have owned it for around 3 years after we brought it as a part built project.
    It is a fiber glass body on a boxed and shortened dodge d100 chassie, straight front axel. The car has gone throght after changes since we have owned it. Here are a couple pics from before we brought it and when it first arrived with us.
    Attached Thumbnails Attached Thumbnails received_10211396340798860_1605811719603.jpeg   20171118_193159_1605811749905.jpg   20171118_193231_1605811778321.jpg   20171121_185426_1605811850826.jpg
  3. #2
    Nov 2020
    10
    It had a 440 low comp engine with a tunnel ram and twin holley 660s to start with, ignition was taken care of by accel coil, 727 torque flite, and a 9" ford rear end with a spool . 9" was mounted by chrome ladder bars. The front was a straight axel on leaf springs with ford transit spindles and brakes..
    Attached Thumbnails Attached Thumbnails IMG-20180301-WA0004_1605811928187.jpg   20171121_190009_1605812124478.jpg   IMG-20180602-WA0001_1605812168789.jpg   IMG-20180519-WA0001_1605812216074.jpg   IMG-20180630-WA0007_1605812247014.jpg
  4. #3
    Nov 2020
    10
    8 months after arriving at ours the car was ready for its 1st trip to the strip. At this point we found out the issues we had with the car. 1st we thought we had care issues so fitted 2 new holley 600 carbs. We later diagnosed the issue down to a faulty dizzy so the accel was replaced with a full msd system. The open single pipe heads went to for a custom set of headers with cherry bombs. We also fitted headlights at this point too. We then headed to strip again, this time car run along better but after lot of messing with the carbs still couldn't get it running 100%. After may hours on Internet I came across an article about balancing vac secondary with a balance tube, so In went an order for 2 spring kits and quick change tops. Then we headed back to the track. The car ran best it ever had running p.b of 16.01 @82mph. At this point we made the choice to put car away for a year. (This was end of 2019 be we know moat people wouldn't be out in 2020)
    Attached Thumbnails Attached Thumbnails IMG-20190205-WA0001_1605812602817.jpg   20190320_170139_1605812651241.jpg   FB_IMG_1559503246628_1605812686372.jpg   FB_IMG_1559504523044_1605812738521.jpg   20190714_151237_1605812954735.jpg
  6. #4
    Nov 2020
    10
    Original plans for car were to have a mild build involving new pistons to up compression ratio, new heads and a general refresh so we pulled and stripped the engine down. One day sat on Facebook and a friend tags me in a reconned 440 block with fully forged rotating assembly. 48 hours later the block was in my garage. Now a mild refresh is a complete engine build. This is the first engine I've ever had built but instead of getting someone else to get the parts I wanted to spec it so following many hours of reading reviews and reading up of technical stuff I ordered the parts over a 2 month period, then found a builder. Only issue he ran into was I ordered incorrect cam bolts. Only thinks I left for engine builder to order was main bearing, piston rings and push rods (this was because I don't have tools to mesure)
    The next issue was will a 727 that the power then new engine has the potential to make, simple answer to that was no. So in the middle of country wide lock down the gear box as loaded on a pallet and shipped off for a rebuild.
    Attached Thumbnails Attached Thumbnails IMG_20190929_153340_1605813797682.jpg   Screenshot_20200312_220434_com_1605813851391.facebook.katana.jpg   20200924_174245_1605814149484.jpg   IMG_20200826_162752_1605814208254.jpg   att_2_1605814488068.jpg
  7. #5
    Nov 2020
    10
    Next decision was to weather keep the tunnel ram or uses the single plane we had. At this point we had a tunnel ram, a tonker 2 and a trick flow manifold. We choice the trick flow meaning we needed a new carb, we choice to go efi root. After more hours of research a holley sniper x flow was ordered with a new billet regulator and fuel pump. Then the msd system was sold to as we have some for a hyperspark system to compliment the xflow.
    Attached Thumbnails Attached Thumbnails IMG_20200516_152453_1605814725734.jpg   IMG_20200731_121534_1605814819582.jpg
  8. #6
    Nov 2020
    10
    Full engine spec
    493ci mopar big block
    Eagle crank and H beam controls
    Domed Diamond pistons
    440 source gridle, damper and sump
    Trick flow 240 heads, cam and intake
    Harland rockers
    Howard cams hyd roller lifters
    Arp head studs, and main cap bolts, cam bolts
    Holley sniper x flow efi
    Hyperspark dizzy, coil and control box
    Msd spark plug leads
    Smith bro push rods
    Milidon external oil system and pump
    Fti torque converter.
    Trick flow valve covers with summit racing valve cover baffles and t.f.s oil cap.
    Moroso catch can
    All none load bearing bolts are stainless, all hoses will be braided hose.
    Attached Thumbnails Attached Thumbnails IMG_20200516_153555_1605815801591.jpg   IMG_20200516_154717_1605815837201.jpg   IMG_20200516_160705_1605815884641.jpg   IMG_20200516_162432_1605815928248.jpg
  9. #7
    Nov 2020
    10
    Next was the need for a brake upgrade. Unfortunately we couldn't find anything to fit our spindles so new 1929-1948 ford spindles were ordered and some big 6 pot willwoods.
    Attached Thumbnails Attached Thumbnails 20200805_174326_1605816071258.jpg   IMG_20200826_205425_1605816093882.jpg   20200805_161852_1605816123504.jpg   20201001_204109_1605816143548.jpg
  10. #8
    Nov 2020
    10
    The front wheels have always been shelby cal 500 with white wall tyres, the rears are 9" slot mags that had slicks.on then replaced with hoosiers. The 9" slot mags will now be used as road tyres as we have got a set of 11" shelby for the rear with mickey Thompson et streets.
    The next question i needed answers to was what spline are my rear half shafts. I pulled them to find out they are 31 spline but had a weird ware marks this lead to the 3rd.member being pulled only to find out that none of the 4 bolts on the main caps were tight. So now the standard 9" rear end is going to be replaced with a hd pro alloy third member hosing a strange s track and 35 spline half shafts all housing in a new braces housing.
    Attached Thumbnails Attached Thumbnails 20180605_115014_1605816393578.jpg   IMG-20171210-WA0006_1605816417612.jpg   Screenshot_20201119-200759_Facebook_1605816549152.jpg
  11. #9
    12,787
    What an amazing transformation! You and your wife are certainly doing it up right with everything you've done to the drivetrain! Thanks for the story and pictures!
  12. #10
    Nov 2020
    10
    Thank you 1946austin. Next is rear axel and 8.5 second tag cage then re build it. 🙂
  13. Remove Advertisements
