correct air/fuel ratio?? - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: correct air/fuel ratio??
  1. #21
    NY
    7,100
    Quote Originally Posted by Dave40 View Post
    Thanks for your input Mario , Much appreciated ,
    You are quite welcome.
  3. #22
    Member
    Aug 2017
    Decatur Il
    62
    Hi guys, I replied once but apparently did something wrong. The Edelbrocks have worked seamlessly, great response, no bogging. All I did was lean out the primary mettering rods. I guess I was curious about the Holleys. It seems like a really good way to go. Right now I'll stand pat with the Edelbrocks. Thanks so much for all the input, Rod
  4. #23
    12,909
    If the Edelbrocks are working, I'd sure stick with them. I've always been a Holley guy, but I'd leave Edelbrocks if I already had them, and was happy.
