'48 Plymouth Special De Luxe
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: '48 Plymouth Special De Luxe
  1. #1
    Member Second Wind's Avatar
    Join Date
    Oct 2020
    Location
    SE Wisconsin
    Posts
    33
    With my work space slowly coming together I'm hoping to start this project soon. I did want to post some pics of the starter project before I start tearing it down. Also being the new guy we will see how my pic post skills are here. Here's to breaking the ice before Jack Frost settles in. I also added a pic of the straight axle I want to use.
    Click image for larger version.
    48 Plymouth Custom Special - 4dr suicide style
    Starting new build from scratch with plans of:
    1950 Chevy straight axle with steering box
    Ford 9" rear with 4.10's or 4:29 gear
    Mopar 440, 512 CID stroker estimating 680 - 700 hp on pump gas
    727 auto
    30 or 32 inch X 10 wide tires
    guessing at finish weight of 32-3500 pound car
    hoping to run in the 10's
    This project will be the quickest vehicle that I have built so I am really looking forward to it.
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #2
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,781
    Looks like a solid car to start with! Is that a 50's Chevy truck axle I see?
  4. #3
    Join Date
    Oct 2020
    Location
    SE Wisconsin
    Posts
    33
    The running board/ rocker panels had some interesting repairs and the fenders need some TLC but it is mostly all there. Yes the axle is just that and it will be used for this project. It came out of a 6 cylinder '50. It has 1-3/4" wide springs so I don't know how well a 440 will go with a spring that narrow. If you look close the tie rod looks really awesome! I think getting the drums off will be a chore too. I see a lot of hours going into the front end this winter. A couple of more weeks and the tear down will begin. I tore down a 440 and hope to have a 727 soon so I can start a mock up. Still trying to decide on a width for a floater 9". A goal would be to have a rolling chassis by spring.
    727 auto
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #4
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,781
    With 6 bolt drums, you'll likely need to swap on '49-'54 passenger car drums, or convert to disc brakes. Speedway sells a disc brake kit for these that will let you not only convert to disc brakes, but also 5x4.5" or 5x4.75" bolt pattern. A very good way to go I think.
    The 1.75" springs likely wont be too lightweight, but you might find they're too long to keep behind the front fenders. I usually dump the stock springs, and buy shorter 1.75" wide springs around 29"-30" long. Those springs are 70 years old now anyway, so might be work hardened after that long, and no telling when or if they might crack.
  7. #5
    Join Date
    Oct 2020
    Location
    SE Wisconsin
    Posts
    33
    Thanks for the tip, I will be needin' 'em. I knew that new springs would be in the works it's just that getting the right ones that fit the project. I will definitely be going to discs too because of the braking capacity and the bolt patterns. Since I started this project I have ended up at the Speedway site more often than not. Lots of good stuff there.
    On a new note I had a good day today. I picked up a 440 short block and 2 each 727's for $500. Once I get a 9" I can start to make it all work.
    727 auto
  8. #6
    Join Date
    Dec 2012
    Location
    NY
    Posts
    6,990
    I used CJ7 jeep springs, others used speedway springs or trailer springs.
  9. #7
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,781
    Quote Originally Posted by mmhotrod View Post
    How long are CJ7 springs Mario?
  10. #8
    Join Date
    Dec 2012
    Location
    NY
    Posts
    6,990
    Quote Originally Posted by 1946Austin View Post
    i have to measure them on the coupe. But they were slightly longer than Chevy stock. I think 33”.
  11. #9
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,781
    Interesting? The specs for those springs show they're 45" long eye to eye.
  12. #10
    Join Date
    Dec 2012
    Location
    NY
    Posts
    6,990
    I will check tonight when I’m home. Maybe I’m off. I can’t remember anything anymore.
  13. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
