Straight axle
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Straight axle
  1. #1
    Member fiftythreechevy's Avatar
    Join Date
    Jul 2018
    Location
    Washington State
    Posts
    34
    Straight axle
    Okay fellas, I am new to the straight axle world. I have been eyeballing the Speedway axles...but I've come across a 55 ford f100 axle that already has disk brake conversion on it. My only concern is spring location as the f100 has wide pads for the spring mounts, dont know if I can alter that. Any input would be great.
    Nick
    There was never a horse that couldn't be rode, there was never a cowboy that couldn't be throwed.
  2. Remove Advertisements
    GasserHotRods.com
    Advertisements
  3. #2
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,569
    Altering spring location isn't something I'd do. I'd alter the mounting points on the frame. Much easier, and safer. Surprising the F100 spring spacing would be wider than your frame rails?
    Might also consider looking for a mid to late 60's Econoline axle. Already 5x 4.5" bolt pattern, and upgraded brakes, or easy to swap to disc brakes.
  4. #3
    Join Date
    Jul 2018
    Location
    Washington State
    Posts
    34
    There is also a 64 f100 straight axle available, but it still has drums. It is 5x5.5 but is only 25 bucks. I'm sure the frame rails are wider than the springs....I think I was having a brain lapse.
    Nick
  5. Remove Advertisements
    GasserHotRods.com
    Advertisements
  6. #4
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,200
    Every thing you need to know about ford axles https://droppedaxles.com/ford-dropped-axles-0
    Lash...Washington Chapter and Member...Mean Old Bastards Club
  7. #5
    Join Date
    Jul 2018
    Location
    Washington State
    Posts
    34
    Thank you Road Angels. I'll do some reading.
    Nick
  8. #6
    Join Date
    Jul 2018
    Location
    Washington State
    Posts
    34
    So it looks like the early 50s all the way up through the mid 60s had the same king pin boss diameter and were essentially the same axle. So the question is, the aftermarket places only sell 5x5.5 for the 64. I can buy aftermarket for the 55 years and get 5x4.5. Is this right or am I missing something?
    Nick
  9. #7
    Join Date
    Jul 2018
    Location
    Washington State
    Posts
    34
    I guess what I'm asking is, the 55 and 64 axelson are identical other than the shock holes present in the 64. If I buy a kit for the 55 brake conversion, it should theoretically work on the 64?
    Nick
  10. #8
    Join Date
    Feb 2011
    Location
    Portland
    Posts
    12,569
    Can't tell you if a '55 brake conversion fits on a '64, as the only disc brake conversions I've done on Ford axles is the Econoline axles.
    As for the spring width, you can either build mounts off the side of the frame, or cut the frame at the firewall and stub 2"x 4" box tubing out offset at the width you need it to match the spring width. A stubbed front frame rails really cleans up the front and makes it not only nicer looking, but lighter, and easier to fabricate mounting points.
  11. #9
    Join Date
    Jul 2018
    Location
    Washington State
    Posts
    34
    Thank you guys for the help, it really is appreciated. I'm going to pick up the 64 axle at least, the guy only wants 20 bucks for it. The guy with the 55 offered to get it to me in Washington through some friends, so I'll probably end up with that one too. Keep you posted.
    Nick
  12. #10
    Join Date
    Mar 2015
    Location
    Washington
    Posts
    3,200
    1953 up have a bigger king pin....earlier years have the same king pin size ... all spindles from 37 up will fit...you have to match the king pin to the spindle...there are different length pins.... 28 to 52 all have the same spindle boss...I would go with a ford f1 spindle do to the weight of the car..check speedway to see what year they offer a disc brake kits for in a 4.5...some of the early spindles from a f1 are perfect for the conversion...you only have to buy one arm for a cross steer setup
  13. Remove Advertisements
    GasserHotRods.com
    Advertisements
Posting Permissions
  • You may not post replies
  • You may not edit your posts
